PhotoImpact 11 Update Pack 1 available on Ulead web-site
klowther
Post by klowther »
You can get it here:
http://www.ulead.com/tech/pi/pi_ftp.htm
Bugs Fixed
Cannot use "Add to EasyPalette" feature in Duotone Effect dialog in Chinese version.
Cannot import workspace profile in German & French versions.
Crash when previewing in Straighten step of Scanned Image Fix wizard.
Crash upon entering Layer Manager Mask mode when document has two path objects with shadows in German and French versions.
Wacom tablet eraser function does not work.
File associations in Preferences do not work.
Crash when opening an image when Image Map Tool is in Mask Mode.
Painting tools cursor displays incorrectly at some Zoom levels.
Painting tools cursor hesitates at edge of images and disappears when moved outside of image onto gray document border.
Shadow is wrong when object is moved separately from Layer Mask.
Export "Packaging" of EasyPalette Galleries now functions correctly.
Cannot launch PhotoImpact 11 TC from Photo Explorer 8.6.
Some Chinese characters cannot be entered using the Windows Input Method Editor (IME).
Does not show Filters Unlimited preview correctly.
Enhancements
Objects with layer masks now display correctly when previewing in browser.
Height/width information for Minolta RAW files now displays correctly.
HDR slider performance enhanced.
Change default JPEG setting in Save for Mobile and Image Optimizer from Progressive to Standard for greater compatibility with mobile phones.
Support for WinXP X64.
- Ken
Bobed2121
Post by Bobed2121 »
here we go again. The installer says it can't find Pi11 on this machine. Well I will bet my bottom dollar that pi11 is in FACT on my machine!!
forficula
Don't do it!!
Post by forficula »
Having just run the update, I would advise anyone considering it - DON'T!!!!
I had to completely uninstall Pi11 and then re-install it before it would work again. As I am a glutton for punishment I did it twice as I thought it must be me or my machine. It wasn't!
d
Xyzzy2
motherboard: MSI Z77MA-G45
processor: Intel i5-3570K
ram: 8 GB
Video Card: MSI R7770-2PMD1GD5 OC
sound_card: Realtek 892
Hard_Drive_Capacity: 6.25 TB
Monitor/Display Make & Model: HP ZR24w
Post by Xyzzy2 »
Please put here exact lenght of the upgrade file (and CRC or MD5 checksum if you can) so that we know when it is updated... :\
X.
klowther
Post by klowther »
What form of install did you guys use (ESD, TBYB) ?
I upgraded from PI 10 with the boxed upgrade version of PI 11 and didn't have any problems installing the update.
- Ken
forficula
Post by forficula »
I experienced no problems upgrading from 10 to 11, both downloads. The problem is with the recently released update, which just wrecks the installed application and it has to be re-installed.
forficula
Post by forficula »
The md5 of the downloaded pi11 update file is:
05c24fa91b97d119c038cddaee98ba93
Of course, there is nothing to compare it with, though I did download it twice, just to be sure.
Acadies
installer can find ...
Post by Acadies »
:cry: well, it cannot find itself, I event when and put the exe patch in the PI v.11 folder and still cannot intall the patch.
I have a full box version.
Xyzzy2
ram: 8 GB
Post by Xyzzy2 »
forficula wrote:The md5 of the downloaded pi11 update file is:
Thanks, if ulead changes the file, we'll know.
X.
Xyzzy2
ram: 8 GB
Re: installer can find ...
Post by Xyzzy2 »
Acadies wrote::cry: well, it cannot find itself, I event when and put the exe patch in the PI v.11 folder and still cannot intall the patch.
You may try Filemon tool from this page:
http://www.sysinternals.com/FileAndDiskUtilities.html
to check for files the patch tries to locate.
On this page:
http://www.sysinternals.com/SystemInfor ... ities.html
there is Regmon utility, to track registry accesses (in case the patch tries to locate PI via a registry key).
X.
richardnau
Re: Don't do it!!
Post by richardnau »
forficula wrote:Having just run the update, I would advise anyone considering it - DON'T!!!!
Same recommendation here. I ran the updater and now my previously working PI11 won't start. It brings up a dialog box that says 'the security information is invalid or has been modified'. (I have a registered and paid for version of PI11. Also had three previous versions, all registered and paid for.)
As a MediaStudio Pro user who was bitten by the latest MSP Hotfix debacle (had to redownload a different version of the original software before I could install the Hotfix), I really should have learned a lesson about applying these patches when they are released.
Next time...
Video editing PC:
C2D E6600 CPU on Asus motherboard
2GB dual channel DDR2 RAM
7600GT PCIe video card
320GB RAID 1 SATA system drive
400GB RAID 1 SATA documents drive
400GB video drive
Samsung and Pioneer DVD burners
Vista Home Premium 32 bit
forficula
Re: Don't do it!!
Post by forficula »
richardnau wrote:
It brings up a dialog box that says 'the security information is invalid or has been modified'. (I have a registered and paid for version of PI11)
I should have said that I got the same message and also have paid for and registered version of pi11.
Thalys
Post by Thalys »
This patch has worked for me without trouble.
Have PI11 ESD
Don't forget to disable any Virus scanner and other similar software before running the update.
forficula
Post by forficula »
I have just tried turning off everything not needed, including virus scanner. The result is the same - uninstall and re-install the application to get it going again.
Xyzzy2
ram: 8 GB
Post by Xyzzy2 »
I only hope that "a patch to the patch" release cycle will be shorter than waiting for the one we got.
And it won't be called PhotoImpact12, with a price...
X.
