dolby digital
dolby digital
I downloaded the VS 9 trial and was very happy with the program. I purchased the program however it is VideoStudio 9 se. It is not allowing me to import a dvd with dolby digital. Is there a plugin that I can download.
GuyL
- motherboard: ASUS P6T
- processor: I7 920
- ram: 6GB
- Video Card: ATI 5870
- sound_card: Auzentech X-fi Forte 7.1
- Hard_Drive_Capacity: 2 TB
- Monitor/Display Make & Model: LG W2753V & HP w2408h
GuyL
- processor: I7 920
- ram: 6GB
heinz-oz
The upgrade is half price ($50). So, if you paid less than $50 for SE, you're still ahead of the game!
If you live in North America (NTSC video), it's probably worth it to get the Dolby. Dolby uses-up 1/4 to 1/3 as much disc space as LPCM. This means you can have higher-quality (less compressed) video, or more playing time on your DVD. (MPEG audio is included in the PAL standard, but not the NTSC standard.)
Note that Video Studio only has 2-channel Dolby AC3. The only Ulead product with a 5.1 channel Dolby surround encoder is Media Studio Pro.
Just for reference.. Video Studio 8 required a $30 AC3 plug-in. (No longer available, AFAIK.)
[size=92][i]Head over heels,
No time to think.
It's like the whole world's
Out of... sync.[/i]
No time to think.
Out of... sync.[/i]
I actually did pay less than $40 for the se so I won't be out anything if I upgrade. Thanks for the advise there DVDDoug. I am probably better off having the cd mailed to me instead of downloaded correct? Download time is not an issue however I believe I read in this forum that the actual cd has less issues. Input would be appreciated and previous help was as well.
heinz-oz
Depending on where you are located, that may be a good option. However, I'm in Australia and only had a physical CD mailed to me once, it cost me another A$ 50.- for the importation
Since then I have, as a rule, only bought the downloads and, apart from the not so smart "Smart Download" issue (easy enough to get around), never had an issue with any of them.
The only percieved shortcoming is the lack of a printed manual with the downloads. Considering the quality of the manuals supplied, not a big loss in my opinion
and the help one can get here outperforms any manual by far
and the pdf manual is easy enough to download also.
Ilene
- motherboard: Thimphu intel Z 170
- processor: i7-6700K quad core
- ram: 16GB DDR4
- Video Card: 6GB NVidia GeForce GTX 980Ti
- sound_card: envy audio AV - band and olfson 5.1 channel
- Hard_Drive_Capacity: 550SSD+
- Monitor/Display Make & Model: Dell Ultra Sharp 25" 2560x1440
- Corel programs: VSX8 32 And VSX9 64 and VSX10 32
dolby vs lpcm
Just a quick question. I make short movies on dvd's using VS9. My video's are usually just 10-15 mins sometimes 20-30 mins, but rarely anything longer. Therefore I also burn everything at the highest quality /highest bit rate ( 8000)...My audio comes from cd's, so they are wav files. If I have the choice, which audio format will sound the clearest. I always choose LPCM, HQ...is there a big difference in the sound of the Dolby. I haven't tried it, but it appears as the default option in VS9.
thanks, Ilene
PS...I'm in North America, so I use NTSC
and in case it's important I render everything as
mpeg2
lower field first
720x480
variable bit rate 8000kbs'
thanks, Ilene
mpeg2
lower field first
720x480
Hi Ilene,
Since you are using small video files, then LPCM should work fine. Dolby Digital or AC3 is just a good audio compression, that reduces the audio file size, maintaining the quality, so that you can get more video, higher quality video on your disc.
The only thing I would advise when using LPCM audio is to lower your video bitrate. The reason is that some dvd players have a hard time playing home made stuff with bitrates that go up to the max dvd spec (9800kbps -- or 10080kbps including subtitles...).
Since you are using Variable bitrate at 8000kbps, there is a potential for some bitrate spikes above your specified max. This means that in the spike areas, you might see video bitrates up to 8500kbps (or higher). Now, add in your LPCM audio bitrate of 1536kbps, and you've got a recipe for playback stutter (as the dvd player chokes on the high bitrate).
I would recommend Dolby Digital audio with a video bitrate between 6000 and 7000kbps -- this should give you a dvd that will be playable on a broader range of dvd players.
George
George
Ilene
- ram: 16GB DDR4
dolby
Interesting...I guess I should try the Dolby. I don't have sound issues with the LPCM...although sometimes songs sound "tinny"...they definitely don't stutter but this is not consistent between players, so you might have a point as to how some players react to the sound!
Now here's a question...when it comes to sound, do the project properties have to match the all the way through the process. For instance, when I start a new project, I set all the properties per the advice on the "Sticky" on this website...then after the project is complete and I go to Share/Create Video file, I choose the option "same as project settings"...then when I go to Share/Create Disk, I usually match all the settings I have been using thus far. What if I switched to Dolby at this point...would it cause a problem? Or am I just better off choosing Dolby throughout?
Ilene
Ilene
