No sound on capture
TM
No sound on capture
Post by TM »
Hi all
Can anyone help me with this problem, i have searched for any similar threads and not found anything similar so here goes.
I am using videostudio 7 which was supplied with my sony DVD handycam dcr-dvd101e.
The problem I have got is when I capture clips direct from the handycam via a usb lead into videostudio and then replay them there is no sound whatsoever.
I have opened windows media player and using the same clip played it back with sound no problem.
I have seperated the sound and video - a sound file appears to have been created but when played their still is no sound.
I have spent many an hour trying to capture different clips with different settings all to no avail
Any suggestions will be appreciated.
Thank You
Post by Trevor Andrew »
Your camera appears to use digital dolby.
Quote from:- http://www.cnet.com.au/photography/camc ... 546,00.htm
(Audio fares better, with support for two-channel Dolby Digital AC-3 audio)
Video studio 7 does not support Digital Dolby.
To play the audio download and install the AC 3 plug in filter
http://ac3filter.sourceforge.net/
This should allow you to hear the sound, but you will not be able to re-code the file using VS 7
Upgrade to VS 9 for Digital Dolby support.
Hope this Helps
Trevor
TM
Post by TM »
Trevor
Thanks for your reply, it is very helpful.
I also found out yesterday after even more digging that the VS7 version I have got is probably the strangled edition so I think upgrading is the obvious thing to do.
Thanks again
