Fade In/Out not available on some clips?
Spud
Post by Spud »
I've noticed that when I trim certain clips or split them up the fade in/out option is greyed out and unclickable. Is this some kind of limitation of V8 or am I doing something wrong? I can use the fade feature on other clips...
Post by BrianCee »
do you mean the fade in fade out icons up the left side of the preview screen :?: :?: - these do not affect the video - they are for the sound - if your clip has no sound then these icons will be greyed out. :wink:
:idea: If you want to fade the video then you should be using the 'crossfade' or 'fade to black' transitions (not forgeting to insert a black block to fade to) available in the F/X library pane under transitions.
Spud
Post by Spud »
Thanks for the newbie tip. Looks like the crossfade is the ticket.
