ive got a problem and cant find anyone that knows wats wrong
ckymikecky666
when i got videostudio 7 it worked fine then recently when i try to open the video editor it just didnt open at all no errors or anything it just doesnt open ive tryed openin it from the shortcut, start menu and from the program files in my computer after failing everything i tryed i decided to try the free trial of video studio 9 and i get the same problem. the video capture and audio editor work fine its just on video editor, someone please help!!!
GuyL
- motherboard: ASUS P6T
- processor: I7 920
- ram: 6GB
- Video Card: ATI 5870
- sound_card: Auzentech X-fi Forte 7.1
- Hard_Drive_Capacity: 2 TB
- Monitor/Display Make & Model: LG W2753V & HP w2408h
aksguitarman
Not sure if this will work for you...but you can give it a try...
See if you have any pop-up blocking software, such as ad-zapper, etc. I have found some problems with the programs, but they are more browser related.
If it used to work. You can try doing a system restore to a point where you feel that it worked.
You can also look for driver updates for your video.
Do you know of any programs that were installed before the problem occured and when it last worked? If so, you can unistall them, try it again, but I would do a re-install first.
If you have another computer, you can try the application on that system to prove that it is not the application.
Hope this helps...good luck
Not sure what your saying ckymikecky666 - do you mean that you can capture with VideoStudio ?? - and what do you mean about the audio editor working - doesn't that mean you have video in the timeline ???
What happens after you have captured with VideoStudio - is the video in the timeline ? - why can't you edit it then ??
