settings for a 240min disc
blue25
Post by blue25 »
hello
i have ulead movie factory 3.
i would like to know what settings i need to record on 240 min disc (4.7GB)
in the settings i have the options of 60 min, 120 and 180 min. and not 240 min
can someone help me
i am able to put 2h on a 2h disc but i want to use a 4h disc
thank you
maddrummer3301
Post by maddrummer3301 »
4 Hour Mode:
NTSC:
FrameSize = 352x480
Video_Bit_Rate = Constant @ 2100kbs
FrameRate = 29.97
Mpeg Audio or Dolby Audio @ 128 to 192kbs
6 Hour Mode:
NTSC:
FrameSize = 352x240
Video_Bit_Rate = Constant @ 1500kbs
FrameRate = 29.97
These modes are valid for 30 days and qualify for mail-in rebate
blue25
answer
Post by blue25 »
does that apply to PAL as well?
what do you mean by mail-in rebate?
thanks for your answer
GeorgeW
Re: answer
Post by GeorgeW »
blue25 wrote:does that apply to PAL as well?
PAL will use different resolutions -- 352x576 and 352x288. The frame rate will go to 25fps.
I think he was just kidding :)
George
p.s. if I were going to use such low bitrates, I would recommend Variable bitrate and 2-pass encoding.
blue25
answer
Post by blue25 »
ok thanks i'll try that
maddrummer3301
What George is saying is to get a better "Picture" if you can use variable bit-rate and 2 pass encoding.
I posted safe recording values.
I have recorded 4 hour's at a Variable_Bit_Rate of 2700. But that's guessing because you really don't know. It depends on how clean the video is and how much motion is in the video.
4 hour mode is for backward compatibliity with video tape recordings. Not usually a good picture when displayed on a 27" or larger TV.
The 4 hour / 6 hour / 8 hour modes of dvd recorders is great for making dvd's for the kid's to watch on the 10" LCD screens in Cars, trips or the small portable dvd players.
Also, small presentations and for teaching purposes.
I'll record on the dvd recorder in 8 hour mode various home movie clips. Then use MF4 to extract them to harddisk. They are small size and then can be emailed out to people. It's a fast method.
MD
