I've looked in the Help file, but find no reference to this. I want to make an object move from the right to the left, however I want it to pause at the middle of the screen for a bit. Right to Left is no problem, and setting the keyframes for position and orentation in the middle is no problem, but getting the object to hold for a second is what I'm having trouble with.
I realize that I could just make new keyframes at the end of the hold time, with the same values as the keyframes at the start of the hold time, but it would be so much easier to just copy/paste those keyframes, like you can do in most NLEs. Is there a way to do that?
Thanks.
Is There A Way To Copy A Keyframe?
Chaser
But, the question still remains, is there a way to copy/paste keyframes?
Yes, there is. Use the Edit/Copy menu to copy and the Edit/Paste Attributes menu to paste. Paste Attributes will bring up a dialog letting you choose which keyframe attributes (Position, Bevel, Etc...) that you wish to copy.
Hope that helps.
- Ken
Chaser
I thought at first perhaps you were mistaken, because there is no option for orientation in that dialog box that comes up, however, I see that just choosing Position takes care of Position, Orientation, and Scale all at once. Beautiful, just beautiful. I'm really going to love having this program in my toolbox of video goodies!klowther wrote: Yes, there is. Use the Edit/Copy menu to copy and the Edit/Paste Attributes menu to paste. Paste Attributes will bring up a dialog letting you choose which keyframe attributes (Position, Bevel, Etc...) that you wish to copy.
Hope that helps.
- Ken
Thank you!!
tommytucker
Does this work for Cool 3D 3.5?
I don't see how to add an additional keyframe at the end of the sequence to paste the attributes onto.
Terry Stetler
tommytucker
Project, Modify...
where is that command in Cool 3D 3.5?
