Is it possible to easily set the transition time exactly rather than having to drag the film clips bak and forth?
EG............. I want a simple cross fade between 2 clips of about 20 frames but when I drag I get 1 sec and 19 frames, then 8 frames and so on. Can I fine tune it or set it exactly?
Fine adjustment of transition time
One way of doing this is to open the Transition Options box and add key frames either close to the start and/or the end of the transition and adjust their transition degree to 0 or 100 respectively. Another way would be to put the two clips on the storyboard, select both and Add to timeline. A dialogue comes up which allows you to adjust the overlap down to single frame level. This can be done in a sub-timeline, if you prefer.
Terry Stetler
