VS9 crashes when trying to change acpture settings
PlymWS
Post by PlymWS »
I have connected my camcorder, a JVC GR-D50EK to my computer via the USB socket. I can start VS9 and the comcorder is recognised. However, when I try and change the capture settings to capture at a higher resolution than the default 180 * 160, VS9 crashes saying it encountered a serious error.
How can I rectify this problem ?
Your camera has DV in.out and so is equipped with a Firewire port (called an i-Link port on Sony and some other cameras) and this should be used for capture of high quality digital video. The USB port, except in very recent, very high end video cameras, is only used to transfer low quality streaming video that you would get from a cheap webcam. It may also, on some cameras be used to transfer still images taken with the video camera.
The problem is that no camera manufacturer of which I am aware ever includes a Firewire cable, but always includes a USB cable if the camera also has a USB port. That gives the owner the idea that it is the USB cable which has to be used, when this is not the case. You will need to buy a Firewire cable, and make sure you get one that has the correct size plugs at each end. Normally they would be a small 4-pin plug for the camera end and a larger 6-pin plug for the computer end. Of course, you will also need to have a Firewire port on your computer, but if you don't have one, a Firewire card is not very expensive these days.
PlymWS
Post by PlymWS »
Thanks Ken. I though it was something like that. Looks like I'll be buying a firewire cable and card tomorrow !
Thanks again.
