Saved frame shrinks from 540 high to 480 high
mlswartz22
Post by mlswartz22 »
When I use the "Save current frame as image" feature the saved image shrinks from 540 pixels high to 480. The width remains at 720 pixels. I tested this by creating a solid red image that was 720 by 540. I then pasted it into the timeline and used the "Save current frame as image" feature. You can see the shrink effect immeditely in the preview window. And when I open the image, it measures 720 by 480. Please advise.
GeorgeW
Post by GeorgeW »
looks like it is saving the frame using the resolution of your project settings (for instance, NTSC could be 720x480).
George
jchunter
Post by jchunter »
You probably have preferences set to :"Fit to project size"
File menu: Project Preferences,
Edit Tab: Resampling Quality: "BEST",
Image Resampling Option: select "Keep Aspect Ratio"
Capture Tab: Captured still image save format: select "Jpeg"
Image Quality: set to 100
mlswartz22
Actually the PREFERENCES, EDIT, IMAGE RESAMPLING OPTION was set to KEEP ASPECT RATIO. When I changed it to FIT TO PROJECT SIZE the problem was solved. Thanx for your help.
