Capturing timecode problems
Jo
Post by Jo »
I need to capture dv with the original timecode of when it was recorded directly from the dv stream. and just can't figure out how to get this working.
When i capture in dv avi format, the original timecode is displayed in the bottom left hand corner of the screen, so i know the software can read it. However when i play back the capture the timecode just seems to reset to being 00:00 at the start of the clip, and any subsequent programs i try which read encoded timestamps, ie Visual DV Timestamp, just comes up with the error "no time/date stamp encoded on this data". What am i doing wrong?
chtchege
Re: Capturing timecode problems
Post by chtchege »
Jo wrote:I need to capture dv with the original timecode of when it was recorded directly from the dv stream. and just can't figure out how to get this working.
If I'm thinking what you're thinking, then you should turn 'Smart Rendering' on. In this way UMSP will not re-render unchanged video sequences (you can change audio as you like - it won't damage the timecode).
