what happened. i reformatted pc & installed xpsp2 &
ozestretch
htchien
Please try to rename the uvAVI.vio in the [Install path]\VIO folder then start Ulead GIF Animator again to see if it fixes.
If it does, some video/audio codec packs in your system is not compatible with Ulead GIF Animator and you will need to remove these codec packs. Usually they are Nimo or XviD codec packs.
Hope this helps.
H.T.
Hope this helps.
H.T.
ozestretch
rename file to?
i have installed K-lite mega codec pack which includes Xvid codec, u mention renaming file, what should it be renamed to? id rather not uninstall that codec i use it for many other projects
htchien
You can just rename uvAVI.vio to any file name you want to see if the codec pack is the problem. If it is, you can contact Ulead Tech Support to ask for updated uvAVI.vio file for fix.
You will get faster response if you phone them.
Hope this helps.
H.T.
Hope this helps.
H.T.
ozestretch
