MPEG Files problem with Windows Media Player
moscar
Post by moscar »
Nature of the problem
After "Add Media DVD" on the "Create Video Disc", I tried to play with the Windows Media Player, the mpeg files on the "Import_DVD" folder.
All the files(good and bad) were imported in the same project properties.
Some mpeg plays good, but other doesn't.
Why?
Properties of your source files (format, file size, where did you get it?)
format=NTSC DVD
file size=138,954 KB
video type=MPEG-2 Video, Upper Field First
What devices are involved and their mode of connection?
I read my DVD on my Vaio Laptop
Project Settings
MPEG files
24 Bits, 720 x 480, 29.97 fps
(DVD-NTSC), 4:3
Video data rate: Variable (Max. 7000 kbps)
LPCM Audio, 48 KHz, Stereo
Do not convert compilant MPEG files
Output format (file, DVD, VCD, SVCD)
file MPEG
PAL or NTSC
NTSC
Error Codes (if any)
NA
System information
Microsoft Windows XP
Professional
Version 2002
Service Pack 2
VAIO Computer
Intel Pentium M
processor 1.86 GHz
504 MB of RAM
Physical Address Extension
maddrummer3301
Post by maddrummer3301 »
What version of MF are you using?
The original release of MF4 had an error that affected the windows media player.
Have you installed the latest update to MF4.
http://www.ulead.com/tech/dmf/dmf_ftp.htm
http://www.ulead.com/tech/dmf/dmf.htm
You also may be able to re-install a software player such as "Power_Dvd" or "Win_Dvd" or similar that may fix the media player.
Hope this helps,
MD
moscar
Post by moscar »
Thank you MD
Rigth now I'm using VirtualDub to convert the mpg files to avi and this resolve my problem.
