Title Animation
Ormond Williams
Title Animation
Post by Ormond Williams »
In the Title Animation window, after I have played one animation, then tried to see what another animation looks like, I can only see the first one I tried.
The only way I have been able to check out another animation is to close the Title window and start all over again.
Is there a way that I can view several different animations before making a final selection?
I have tried both clicking and not clicking the "Apply Animation" button, but neither way allows more than one animation to be viewed.
Terry Stetler
Post by Terry Stetler »
Please check the "Sticky" post "How To: MSP8 - removing title styles, animations and effects" at the top of this forum for your answer.
Terry Stetler
Ormond Williams
Title Animation
Thanks Terry,
I had seen but not read that sticky item. My brain was not switched on when I saw it's title! Sorry!
chyao
Re: Title Animation
Post by chyao »
Ormond Williams wrote:Thanks Terry,
There is more simple method to remove title animation and type effect.
1. To select one title which has apply title animation in the preview windows.
2. To change the production library tab to title animation tab.
3. To click mouse left button in a blank space of production library of title animation tab, and the selected animtion item will be deselected.
(Do not hit any title animation item.)
Then the title animation will be removed.
Type effects work the same way.
Hope it can help you. ^_^
