I recorded an in-game movie of Guild Wars with GameCam, I edited it completely and saved it. It works 100%. But when I add audio and try to save it, I have a small problem:
1)When I use "Same as project settings", The audio is added, but the movie is 720*576 instead of 512*384.
2)When I use "Same as first Video Clip", the size is right (512*384), but there's no audio.
I tried changing the size to 512*384 in the first case, but "user defined" in frame size is greyed out. Any ideas?
Audio problem when saving file...
By what you posted your Project Properties are set at 720 x 576. When you elected to "Save as project settings" the program done just that.
What version of Video Studio are you using, and what are the properties of your video clip? How did you capture it?
Regards
Regards
The High Lord
The problem appears to be the format, MPEG4. Have you downloaded and installed the MPEG4 plug-in?The High Lord wrote:I am using the latest version of Videostudio. (9 I believe)
The original file (which I captured using a program called GameCam):
512*384
30 FPS
221 kbs
16bit
MS-MPEG4 v2
The file after editing:
512*384
audio:
1536 kbs
16bit PC
video:
187 kbps
30FPS
24bit
MS-MPEG4 v2
