1) it is easier to do it accurate as in DWS2 (because I can zoom in)
2) I can add I-frames at chapter points during rendering
When I however insert / delete / modify any clips (e.g. adjust duration of tilte clip), the chapter points are not adjusted. So I have to do this manually
Would be nice if it would be possible to save the chapter points to an ascii (or better unicode) file and to also import them from such a file. So I could edit them with a text editor, print them, verify them, ... Any way to do this?
As I saw they are encoded in a separate stream in the mpeg (or avi) file. Is this a standard way or will this be only understood from DWS2? (DWS2 is much older than MSP8, so any support for this format was build in long time before.)
