it was when I install VS9 (the plug in makes no difference).tyamada wrote:When does your TV stop working, after you install VS9 or when you install VS9 plugin for the Hauppauge card?
If your TV still works after installing VS9 and before installing the Hauppauge plugin, don't install the Hauppauge capture plugin.
I found trying to install the HDV and the Hauppauge plugin on VS9 conflicts with each other. It depends on the install sequence on which plugin I can use. Both plugins will not work together.
Video Studio 9 and MCE
ss_lbs
Here is a thread you might be intrested in. http://phpbb.ulead.com.tw/EN/viewtopic. ... ghlight=mc
You should also do a search for MCE, there are numerous post about the same subject.
