When I make a DVD with play the next clip picked it works fine until I hit the next clip/chapter button then when it gets to the end of that clip it goes back to the menu instead of the next clip. If I never hit the next button it will play ok.
Anyone have the same problem or have any ideas how to fix it?[/b]
next clip problem
thomasji
next clip problem
Thanks I allready found that post.
I am not working with hidden chapters and the post you mention has no solution.
maddrummer3301
Maybe the program is supposed to work that way.
Similar to a commercial dvd. You can skip chapters using the remote and
after that clip (mpeg2)file/movie is down it returns to the main menu.
Maybe the dvd is marked to play the next clip but once you hit a button to jump around the dvd player itself goes into manual control.
I know some of my VCD's do that.
MD
MD
thomasji
next clip problem
Well my DVD recorder DVD's work the way they are suppose to, they goto the next clip. So does every commercial DVD I own.
By the way PS4 works just like MF4.
Ulead has nevery made a DVD or VCD that navigated the way they are suppose to.
Their tech support seems to be non existant!!!
