How can I insert a running time clock in VideoStudio?
...and to complete what Steve said:
But if you have the project selected, it will show the filter's effect at the cursor position in the preview window for a check, only it is not visible WHILE you play or jog the clip.
So it's still easy to check how it goes by using f.i. the timer box to check second-by-second (or frame) how it displays.
stahlmangc
- ram: 2 GB
- sound_card: Intel GMA 950
It should work in the trial version. Have you placed it into the correct location.
The Full version it goes here:
C:\Program Files\Ulead Systems\Ulead VideoStudio 9.0\vft_plug
The trial version will be slightly different and something like
C:\Program Files\Ulead Systems\Ulead VideoStudio 9.0 Trial\vft_plug
Sorry cannot be more specific on the correct path to the trial version as obviously I have the full version.
Regards
Steve J
Regards
Steve J
stahlmangc
GillesAmez
Hi all,
I recently bought Ulead VideoStudio 11.5 Plus, and searched for a timer plugin (incar racetrack video -> laptimer).
I downloaded the filter, put it in the correct folder, and was able to put it on a video fragment in the videotrack.
However...
Thanks a lot,
Kind regards,
Gilles[/list]
However...
- How can you edit the starting/finishing point of the plugin? E.g. a fragment of 3 laps and a cooling down lap, and I only want to "time" the third lap?
- The counter runs far too fast, compared to actual seconds. It runs aproximately 60% too fast. After 10 seconds it's already at 16 seconds. How can you alter this?
- The aligning function does not properly work. When the video is paused, the counter is where it should be (in the rearviewmirror), but upon pressing the play button, it shifts to almost outside the video frame.
- The font is very blurry, as if it were a font size 8 but then blown up to match the size I desire (e.g. 24).
Thanks a lot,
Kind regards,
Gilles[/list]
daddog
Re: How can I insert a running time clock in VideoStudio?
Anyone know if this works with X3?
aka James or dd :)
MB Gigabyte GA-EP45T-UD3P
CPU Intel 2 Duo E8500 3.16GHz
Windows 7 64bit
GeoForce GTX 260
4GB of RAM
DirectX 10
LiteOn DVD Burner SOHW-1693S
Sony HDR-CX550V camcorder
http://www.332nd.org/
Windows 7 64bit
GeoForce GTX 260
4GB of RAM
DirectX 10
What? The timecode filter? Yes it works with X3.
Jeff
Dentler's Dog Training, LLC
daddog
Hi BL!
Well, I am looking for something that would act as a 'time counter' in the clip. Just ticking away the seconds in one of the corners.
The directions for the above item mentioned:
1. Open Video Studio
2. Drag a clip to the timeline
3. Click the drop down box below the Video Studio 9 logo
. Then select "Video Filter" A new one will be in the selection of thumbnails
. "Timecode"
4. Drag the "Timecode" thumbnail onto the clip on your timeline.
5. At top left of your screen the attribute option is now displayed.
. There is an option to "Customize Filter"
In addition to the obvious choices of font, colour etc, click on the preview screen the location you wish the timer to appear.
I don't see how to get it to work with X3.
. "Timecode"
aka James or dd :)
Windows 7 64bit
GeoForce GTX 260
4GB of RAM
DirectX 10
Windows 7 64bit
GeoForce GTX 260
4GB of RAM
DirectX 10
Assuming you have the filter installed into X3, with your video clip on the timeline you click on the FX button to bring up the filters. Click on the Timecode thumbnail and drag it down to your clip on the timeline. Customize the filter as needed.
Jeff
Also you will not see it work while previewing in VS. You need to go to Share>Project Playback to view the time clock. I just tried this in VS X3 and it does work. Just a quick way to determine if it is going to work, scrub the time-line, you will see it then.
daddog
Must be doing something wrong.
Opened the zip file 'time code'. Dragged and dropped the 'timecode.vft' file into the X3 folder called 'vft_plug' In my C Program files/Corel/Corel VideoStuido Pro X3 folder.
Opened up X3, put a clip in the time line and then looked in the Special Effects folder. Don't see anything new. Looked under 'all' and also looked for a new option in the Special Effects drop down menu. No joy.
aka James or dd :)
Windows 7 64bit
GeoForce GTX 260
4GB of RAM
DirectX 10
Windows 7 64bit
GeoForce GTX 260
4GB of RAM
DirectX 10
Ok, I see that it isn't showing up on my Vista machine. It does work with VS versions ran on WinXP and older. A google search for Robotiq filters, just leads back to this forum, maybe one or two others, however all having to do with Ulead MSP. So I would say that filter is so old and that Robotiq is no longer around, it will not work on current operating systems.
NewBlue's Video Essentials IV includes a time clock filter.
Jeff
