I captured some VHS video from my VCR using an ADS USB 2.0 capture devise and Cap Wiz. I edited my project with no problem and burned to CD using the recommended practices found in this forum.
After burning the DVD played back fine on my LG 2166 burner as well as on Windows Media Player.
When I attempted to play it on my household DVD player (Toshiba) it played perfectly except fot no sound. I kept goping throught the tutorial & burned 3 more discs with the same results.
Finally on the last try I looked at the DVD players menu and set the audio to Analog and this solved the problem.
Will this be an ongoing issue and do I have to set the sound to analog (if possible) on every player I want to play it back on.
Thank you for all your help.
Problem with sound in Video Studio
Since we don't know where you live or what the properties were of your poject or the original videos that went into it, much less your computer specifications, it is difficult to say. But if you are in a NTSC country, and used mpeg layer 2 audio, it is possible that your Toshiba is not built to play that audio format. Mpeg layer 2 audio is not part of the NTSC DVD standard, so it is optional for NTSC to be able to play it. If you select LPCM audio, see if that will play. If you have VS9, you could also try Dolby AC-3 audio, which produces a much smaller audio file (so you can fit more video on the disc).
cnl390
I'm sorry but I was at work when I found that my membership was activated.
I live in San Antonio, TX
As well as I remeber ( I can post for sure later)
Processor - Pentium 4 2.4GHz
768 RAM
Rage video card
Creative sound card
Maxtor hard drive
Project
NTSC
Upper field first
Variable 3998
Mpeg Audio 224
Slider at 100%
Burned at 2.4X
Media Verbatim DVD+R DL
768 RAM
Rage video card
Creative sound card
Maxtor hard drive
Project
NTSC
Upper field first
Variable 3998
Mpeg Audio 224
Slider at 100%
Burned at 2.4X
cnl390
OK here are the stats...
File
Format NTSC DVD
Size 882496 kb
Duration 1682.316
Video
Type MPEG-2 Video, Upper Field First
Frames 50419
Attributes 24 bits, 720x480 4.3
Frame rate 29.970/sec
Data rate variable max 3998
Audio MPEG Audio Layer 2 Files
Total Samples 80715.151 samples
Attributes 48000 Hz 16 bit stereo
Bit Rate 224 kbps
File
Format NTSC DVD
Size 882496 kb
Duration 1682.316
Video
Frames 50419
Bit Rate 224 kbps
