Its a home movie with about 8 chapters and the video stops after each chapter even though
Klaus Christo
I have not had this problem before and am wondering why its happening now? Can anyone help?
I ticked the option 'continue to play the next clip'
Kaz
rguthrie
- motherboard: MSI MAG B550 TOMAHAWK
- processor: AMD Ryzen 9 5900X 120-Core Processor
- ram: 64GB
- Video Card: AMD Radeon RX6600 XT
- Hard_Drive_Capacity: 2TB + 4TB
- Monitor/Display Make & Model: ViewSonic
Klaus Christo
I want a menu but I dont want the video to stop after each chapter, I know it usually does continue playing, but for some reason it suddenly decides to go back to the menu screen after each chapter.
Kaz
Klaus Christo
Separate video clips are called Titles, while marks within a title are called Chapters.
Since you are using separate TITLES, then check the little gear icon, and see what you have selected to do after each title (probably set to return to menu). Set that to play next clip, and you should be all set...
hth,
George
hth,
George
Klaus Christo
Yes George that is what it should do but unfortunately it dosn't.
As I said right in the beginning I checked that option, certainly seems strange, I have burnt other dvds and never had this problem, hope this isnt going to happen all the time from now on then I will have to go to another program.
Thanks george for correcting my terminology, I must get it right.
Kaz
Klaus Christo
Klaus Christo
Well I finally worked out the problem all by myself.
Simple, when you make titles (which I called chapters) you have to add chapters ie go to the add/edit chapter and make a couple of chapters in the titles in order for them to play without stopping at the next title.
Took me a while to work that out, seems a bit weird too, seeing I did tick the option in Navigation control: 'continue to play the next clip' but that did not make the dvd go from one title end to the next.
Kaz
Hi Kas
I had similar problems with the navigation controls.
After creating the first dvd and finding I had used the wrong navigation, I wanted to change it, reverting back and altering the navigation controls made no difference.
By starting a new burn project allowed me to select navigation option that worked.
Hope that makes sense.
Installing the latest ‘Burner Update’ Cured the problem for me.
Trevor
Trevor
Klaus Christo
If your asking about the burner update for VS9 it can be downloaded here:
http://www.ulead.com/tech/vs/vs_ftp.htm
Klaus Christo
