Smart Compositor - Heres 6 more
rs02931
smart compositor
Post by rs02931 »
Thanks Steve.....
worked fine for me as well....
msp8 NOT running
Downloaded your files
opened files
Started MSP8 - VOILA there were there
Thanks again
krwzmann
Post by krwzmann »
Yup exact same thing with me. When I click 'ok' after running the .exe, it says it will take a few mins to load but it only takes a few seconds before the screen dissapears.
I am running the full version of MSP8 but it was the tbyb (try before you buy) version. Wonder if that makes a difference?
lotus wrote:I was not able to download the 6 templates. MSP8 was not open.
I opened the .exe files and then opened MSP8 - no Steve category
in smart compositor. I tried several times and even rebooted
computer, but still no Steve category. After I click "ok" on the
.exe files - I can visually see the motions of the files downloading but
it does not get into MSP8.
Dell Dimension 4600
Pentium 4 - 2.80 ghz, 1.0 gb ram
Microsoft XP Home SP1
lotus
Post by lotus »
I have the box version of MSP8 and not the try before you buy.
You're right - it took only a few seconds to complete all 6
downloads and not a few minutes. An earlier post indicated these
files would be located in C:/programs/UleadMSP8/uct_plug.
I opened that file and a whole bunch of folders with numbers
opened up. Even clicking on them doesn't give me a clue as to
where Steve's templates went. Is there a work around? I don't know
where the download went - do I need to find these files first before
and delete them before attempting again. I've tried to download
at least 5 times without any success.
Dell Dimension 4600
lotus
Thank you for trying. Would you be prepared to try a little experiment for me . I have zipped the files created here:
http://www.steve-jones.pwp.blueyonder.c ... rtcomp.zip
It is a massive 17kb in size!!
if you unzip it to the root directory "c" and ensure that you have checked the option "use folder names".
This hopefully will contain all 6 of the smart compositions.
If it doesn't work just look in the zip file for the 12 file names and locations and then you can delete them again.
Either way could you let us know the result, it may be a work-round for others.
Regards
Steve J
lotus
Post by lotus »
Steve,
Success at last!!!
I followed your last set of directions to unzip folder and it worked.
MSP8 was not open. I downloaded your link and unzipped folder and
then opened MSP8 - your "Steve Jones" templates where you said
they would be. Templates work just fine. Thank you for the work around and the templates. Great work Steve!
HankM
Downloads
Post by HankM »
They work fine. Nice job. Thanks
Hank
lotus
Post by lotus »
Forgot to mention earlier, there was no option for "use folder
names" - I just made sure it went to "c" and unzipped and templates
went into MSP8.
krwzmann
Post by krwzmann »
Yipee! The workaroun worked for me too. Good job and thanks again!
bubbawhite
Post by bubbawhite »
Steve,
They work well! Thanks for your hard work!
Glen
mathis
Post by mathis »
Okay, Steve, I downloaded and installed all six of them and I do have the other file you mentioned later. I clicked on Smart Composer and Steve Jones was there. All of the templates were there. But when I opened them up and changed the color blocks to my videos (even tried images), the color blocks didn't go away. The image/video that I placed in the
blocks on the Story Board appeared correctly, but when I hit play, the colored blocks you created remained. I tried changing the music, also, but it stayed the way you created it. I clicked "Insert" to send it to the timeline and it remained the way you created it. I was unable to change anything. I have used Smart Composer frequently, since I got MSPro 8.0, so I know how to use it. I do have version 8.00.028, but I don't have any hot fixes because I didn't have anything on the list that was posted some time ago that needed it.
Thanks.
Mathis...
sjj1805 wrote:Strange that because they couldn't be simpler.
Simple colour blocks in place of the pictures
Smartsound for the music - one of the tracks that ships with MSP8.
Anyone managed to download a working copy?
Steve J
Obviously they work on my machine otherwise I wouldn't have posted them.
Could I ask if anyone else is having this problem and also are they working correctly for anyone.
Obviously we all need to know the answer to this before we all start creating these in the hope of sharing them.
Regards
Steve J
jday
Post by jday »
I just tried inserting video clips in place of the color blocks and it works perfectly.
Mathis, are you inserting the videos/pictures in Smart Compositor and DELETING the color blocks before you insert the SC video into the timeline? That's the way I did it and it worked.
HankM
Smart Compositor
Post by HankM »
Steve,I just drop the pix or video clip on top of the colored
clip in Smart Compositor and bingo, done.
Hank
mathis
Post by mathis »
Jday, I just dropped my video/pictures on top of them -- that's the way I do it on the supplied ones....
Okay, I just tried it again by just dropping it on the black box that says "Drop Video Clip to here" then deleted the yellow box and it did the same thing. Here you can see the results:
http://members.cox.net/mathisbrogers2/SmartComposer.jpg
notice on the display screen that the yellow box is still yellow, not the the water.
Here is the result of one that I did with the supplied. The middle picture of the lady is the one I changed -- it's actual video. The ones on the right and left screen are defaults.
http://members.cox.net/mathisbrogers2/S ... oser-1.jpg
Thanks.
Mathis...
jday wrote:I just tried inserting video clips in place of the color blocks and it works perfectly.
Mathis
Here is how I do it
Steve J
