How Do I copy my videos to another Master DV?????
FUVideos
Post by FUVideos »
Trying to figure out how to use ULEAD, its very confusing. I have some content of mine on Sony DVCAM master tapes and I want to be able to make a copy of it onto a mini DV tape. First of all, is this possible using VideoStudio9 to make copies from my Sony DVCAM master to a mini DV tape? and secondly, how do I do this?
Any help would be greatly appreciated.
Thanks,
Adrian
Post by BrianCee »
The first question would be - do you actually have something which plays the DVCam tapes - what is the output from that device - if it is firewire then why can you not just connect the player to your PC and capture it and edit it and then export it to a blank tape in a digital camcorder just as you would with any other video from a digital camcorder. If the DVCam tape player does not have firewire output then put whatever output it has through a converter and capture it - or simply capture as analogue - either way what you want to do is pretty standard stuff and is all covered by the manual.
Also once you have it within Ulead VideoStudio you can burn as many DVDs as you want - again pretty standard stuff.
