No AC3 audio option MSP 7.30.1003
patc
Post by patc »
I was looking at some docs on the MSP 7 and noticed it mentioning AC3 or dolby as an option under the video save audio settings.
I do not have that option onmine. Is there a download somwhere I missed? I looked on Uleads website and couldn't find anything for that functionality.
Any assist would be great.
Have you applied the following patch
Ulead MediaStudio Pro 7.01 Update Patch (Release Date: 5/21/03)
Found here
http://www.ulead.co.uk/tech/msp/msp_ftp70.htm
Terry Stetler
Post by Terry Stetler »
IIRC the Dolby option only appears if you're exporting using the NTSC or PAL DVD profile, not the generic MPEG-1 or MPEG-2 profiles.
Terry Stetler
GeorgeW
Post by GeorgeW »
Terry Stetler wrote:IIRC the Dolby option only appears if you're exporting using the NTSC or PAL DVD profile, not the generic MPEG-1 or MPEG-2 profiles.
This sounds right to me -- I uninstalled MSP7.x, but I believe when you selected the mpeg-x profiles, you didn't get the AC3 option (as Terry said).
George
patc
Post by patc »
when I am creating a project from my captured video *(video properties below) and trying to match the project to it in Video Editor I am selecting NTSC-DVD profile and the capture video properties has Dolby Digital but I can not match it because my choices are only Mpeg and LPCM.
Even if I try and create a new profile, Dolby AC3 is not available on the list.
As for the patch, I did install everything up to version 730.1003 so I am going to try and uninstall and then reinstall service packs. Does it matter that the website that was given above is UK? I am in US.
*(Video Profile after capture using Video Capture DVD-VR)
.mpg
Vid Format: 24bits, (704x480),4:3
compression: NTSC DVD, Upper field first, Variable bit rate (max 9300 kbps)
comp Ratio: 6%
Frame Rate: 29.97 fps
Total Frames: 24,066
Audio: Dolby Digital AUdio 48000 hz
