Hi Guys,
I have a P4 3.2GHZ, 1.5GHZ memory and 30Ghz free space in the C-drive and using VS9. My problem is in rendering. After I finished capturing and editing my video and started to share(make DVD), it stops after 11%, and sometimes 40% during rendering. The program just stops, could you be kind to help me with this problem.
thanks,
David
problem rendering
- ram: 2 GB
- sound_card: Intel GMA 950
pnoydad
Please view the following links:
http://phpbb.ulead.com.tw/EN/viewtopic.php?t=27
and
http://phpbb.ulead.com.tw/EN/viewtopic.php?t=8959
Please update your system details on your user profile page.
and
A common reason for faults in the burning process is following the wrong procedure. The recommended procedure is outlined in the top sticky post on this Board. To summarise, you should NOT be going straight from the project in the timeline to the burn module (Share > Create Disc > DVD) which it sounds as though you are doing. INSTEAD, you should use the preferred method which is to first produce a DVD-compatible mpeg-2 file (Share > Create Video File > DVD). Once you have this file, close your current project, and then click Share > Create Disc > DVD. This will open the burning module. Insert your DVD-compatible file(s). Make sure you click on 'Do not convert compliant mpeg-2 files' in the little cog-wheel icon in the bottom left of the burning module screen. Add your menu, chapters etc, and burn either the DVD itself or produce a disc image or Video_TS folder if you intend to burn more copies later.
If you are not using this method, then the wide experience here is that you are asking for trouble.
pnoydad
rendering fixed
thanks Guys, my rendering problem is solved. I produced a DVD-compatible-mpeg2 file first and then created a DVD.
The procedures on the following link really helped (I should have read this in the first place):
More Power To You,
David
More Power To You,
David
