Can any one download Ulead MPEG-4 Plug-in for VideoStudio 9
Glennmizu
Post by Glennmizu »
I have tried and I have the Pop-up blocker off and I have entered my
Serial Number correctly but. Every time I try nothing happens.
Has anyone managed to download it or the HDV Plug-in?
Cheers
Glenn Waters
www.glennwaters.com
rtc2901
Post by rtc2901 »
I downloaded both without a hitch (although if I remember correctly, I had to switch to IE for a sec rather than Firefox).
Glennmizu
Post by Glennmizu »
Hi. I am useing IE but no luck. I hear a click like pop-up blocker but it is off. Tried turning off mt security but still no luck
Cheers
Glenn
Glenn,
Is your MT security your Firewall? I had to disable it too in order to download it..
Do you have any special toolbars like Yahoo or Google? If so I know Yahoo has it's own pop-up/spam blockers on it. You might check them.
Another thing to check is JavaScript. JavaScript is where the code is written for pop-ups. Of course if you had JS completely disabled there's several websites that wouldn't function and you could tell by that.
However by what you are describing, it does sound like a pop-up blocker working...
Regards
Glennmizu
Post by Glennmizu »
Thanks for the help. I didn't know that windows had a pop-up blocker and that was the problem.
I had only turned off the Yahoo pop-up blocker.
Thanks again.
Cheers
Glenn Waters
hotdiscomix
Post by hotdiscomix »
Hi Glenn,
I have the same download problems here in Germany.
I have send an email to Ulead support and have tell my problems. As reply I have got an email with two download links and the MPEG-4 activation code.
Both links works perfectly.
tinkertoy
Has anyone received a reply from Tech Support
Post by tinkertoy »
Has anyone received a reply from Tech or Customer support regarding the failure of download MPeg 4 plug-in. I am still waiting and I m now concerned that I have used all my grace submissions of being able to download the Plug-in.
If anyone reads these postings from Tech/Customer support then please reply.
I have tried to download from three different locations without success.
Glennmizu
Post by Glennmizu »
Hi Guys,
just open the toolbar on Internet Explorer and you will see Popup blocker. Just turn it off and then try and download again. It worked for me.
Cheers
Glenn
www.glennwaters.com
DanEG
Post by DanEG »
I'm getting an error message that my frackin' serial is invalid.
how long did you guys have to wait on digital downloads? did they all work instantly? :?
EG Guy
MPEG4 Download
Post by EG Guy »
Hold CTRL key down when you click submit and download link should open. 8)
Glennmizu
Post by Glennmizu »
Hi DanEG
I got the same message until I entered the members’ area and copied my number then I pasted it in the box on the download application page. Then it worked no problems.
Cheers
emil
Activation code - I cannot use any activation code....
Post by emil »
Any body pls help....Is there any simple code for me to use for the moment.
Hi emil welcome to the boards,
What version are you using? VS9 full registered? or VS9SE? You ask if there is any simple code for you to use at the moment? If you have a full registered version, either boxed, ESD, or Upgrade then you have the code that you need. If you don't then your version does not quailify..
Regards
TBA
Post by TBA »
I turned off my pop-up blockers and tried several times. At last I found out that I had to deactivate Norton Internet Security. Then the download page came up. I think this is awkward. Isn't it possible to make this download easier? They should at least inform about turning off internet security.?
