Hello. I've been trying to add an edge preset to a photo - number 26 in this case - and I cannot find any way of changing its colour or making it transparent.
Is there any way to do this?
It is to be used on a webpage with a dark green background and I would like the frame area to either match that colour or be transparent so that the dark green shows through.
Hope someone can help; you have my thanks if you can!
Well, you can do two different things. Once you've applied the edge preset, use the magic wand to select the white part. Then fill the white part with a color of your choice.
The other is, after you apply the preset, use the magic wand to select the white part, right-click, Invert, and convert to object. Then drag the image off to a new window and hide the background.
[url=http://pircnet.com/]PhotoImpact Resource Center[/url]
[url=http://wwell.net/]Wishing Well Tutorials[/url]
[url=http://pircnet.com/forum]PIRC Forum[/url]
Hi again. Just confirm that I got that to work okay. I had to deal with a few orphaned white areas, but that was easily cured by copying the selected area onto a new image and then filling it in.
