Hello everybody,
Sorry for my english, i'm french
I've problem for recording
I made a movie of 39 minutes and when i want record on DVD, only 32 minutes has recording on DVD.
Why ? What's the problem ?
Thank for your help!
Incomplete recording
spider13
- ram: 2 GB
- sound_card: Intel GMA 950
I am having to answer this from memory as I am currently at my workplace and not in front of my own machine.
When you you render the file it asks you to give it a filename etc.
There is an "Options" checkbox. Select this and I think you find it there.
If not unless anyone else has answered before I get home I will check for you later.
Steve J
Steve J
spider13
thank for your answers.
But I want create DVD disc and not create video file.
I think that i have found where is the problem.
When i click on "Create Disc", the soft load automatically my project.
The lenght is 32 minutes.
So I delete and I reload the project and the lenght is 39 minutes
Tomorrow, i will start the rendering.
I'll say you if is OK
regards
René
regards
René
Steve's point remains a valid one. A common reason for faults in the burning process is following the wrong procedure. The recommended procedure is outlined in the top sticky post on this Board. To summarise, you should NOT be going straight from the project in the timeline to the burn module (Share > Create Disc > DVD) which it sounds as though you are doing. INSTEAD, you should use the preferred method which is to first produce a DVD-compatible mpeg-2 file (Share > Create Video File > DVD). Once you have this file, close your current project, and then click Share > Create Disc > DVD. This will open the burning module and also ensure that your current project is not automatically loaded. Insert the DVD-compatible file(s) instead. Make sure you click on 'Do not convert compliant mpeg-2 files' in the little cog-wheel icon in the bottom left of the burning module screen. Add your menu, chapters etc, and burn either the DVD itself or produce a disc image or Video_TS folder if you intend to burn more copies later.
If you are not using this method, then the wide experience here is that you are asking for trouble.
