Font on 2nd page DVD menu resets to Arial
golem
Post by golem »
I burned 2 DVD projects now with VideoStudio 9 (update pack installed) and both have the same problem:
I used Clas02 and Natu02 menu templates. They have preset fonts according to the template style. In the final DVD preview everything looks fine. But on the burned DVD only the first menu page appears with the correct fonts, from the 2nd page on the font is Arial, which looks crappy with the template.
I created a regular NTSC-DVD with the "Create DVD folders" option. Any fix/workaround?
Thanks!
rguthrie
motherboard: MSI MAG B550 TOMAHAWK
processor: AMD Ryzen 9 5900X 120-Core Processor
ram: 64GB
Video Card: AMD Radeon RX6600 XT
Hard_Drive_Capacity: 2TB + 4TB
Monitor/Display Make & Model: ViewSonic
Post by rguthrie »
golem,
When you click on your text to edit it you get a pop-up window titled "Edit Text Description". Check to see if "Same font for all pages of this menu" is selected. However, unless you changed the font, it should remain consistent with the preset template.
Hope this helps,
Ron G.
golem
Post by golem »
hi rguthrie,
thanks a lot, this fixes the problem. I had not changed the font, still it was back to Arial on the DVD output, while the preview looked fine.
