A-2166 error on audio files during VS9 install
blitzkow
Post by blitzkow »
During installation of VS9, I encountered this same error on several of the audio files. Some it complained about during the installation, others "appeared" to install ok.
When I go to the Audio/Auto Music tab, I get another error message saying "Please insert the SmartSound Library CD "Full Spectrum 22K" .
The audio files in the demo worked fine.
What's wrong :?:
rguthrie
motherboard: MSI MAG B550 TOMAHAWK
processor: AMD Ryzen 9 5900X 120-Core Processor
ram: 64GB
Video Card: AMD Radeon RX6600 XT
Hard_Drive_Capacity: 2TB + 4TB
Monitor/Display Make & Model: ViewSonic
Post by rguthrie »
blitzkow,
If you have QuickTime 7 on your system, you'll need to uninstall it, then install the SmartSound files. Then go to http://www.smartsound.com/support/updates.html to get the update for QuickTracks (for compatibility with QT7). After that you should be able to reinstall QT7.
Hope this helps,
Ron G.
blitzkow
Post by blitzkow »
Thanks Ron,
One thing, how do I install the Smartsound files without reinstalling the entire VS9 product again?
Bruce
rguthrie
ram: 64GB
Post by rguthrie »
blitzkow,
There should be a folder that contains your SmartDownload packs. Go to C:\Program Files\Ulead Systems\Ulead VideoStudio 9.0\SmartDownload and you'll see it there. I recommend that you make a disk backup of all the SmartDownloads and the update packs as well so should you need to ever reinstall you'll have everything already.
Ron G.
blitzkow
It works now
Post by blitzkow »
I figured out how to do what you had described in your previous reply and now all the music works. Thanks again for your help!!
:D :D
