The memory could not be read!
maddrummer3301
Post by maddrummer3301 »
>>Now, let's go back to my question, anyone has any experience with
>>the trouble of "the memory could not be read"?
Yes, I have. Always save the project.
The "Read Me" doc for MF4 says if problems to increase the paging file.
Occasionally I delete the paging file to start off and have a clean one.
I've noticed that MF4 uses alot of memory. Any problems I've had is
usually when the machine runs out of real memory and starts using
the paging file.
MF4 has been running well on my machines. On all my machines I
have the windows priority set to background (not programs).
(Don't know if that has anything to do with it, I'm just use to running
true multi-tasking operating systems, windows isn't true multi-tasking,
only a matter of preference).
I use Norton Anti-Virus 2003. Before starting MF4 I always right-click
on the icon and disable active monitoring.
I also installed VS after MF4. Seems like the more I used MF4 the
better it runs.
MD
Chief Monkey
Post by Chief Monkey »
Found this @ ULEAD
http://www.ulead.com/tech/vs/vs90faq.htm
The info is :arrow:
I get this error message, "MEMORY COULD NOT BE READ.” What do I do?
Increase your virtual memory. Go to My Computer > Properties > Advanced > Performance > Settings . In the Advanced tab, click Change and set the virtual memory as the values shown below:
Custom Initial Size: 1024
Maximum Size: 4096
Click Set then OK . Restart your computer. :idea:
Did not try it yet, but will tonight!
8)
