It is quite often an annoying problem occurs when I am burning disc using DMF4.0. A report to Microsoft was produced first, and then the following error warning appeared:
“The instruction at "0x123456789" referenced memory at "0x00000004". The memory could not be "read"”.
The DMF4.0 was forced stopped and retuned to the original state.
I have read few instructions on other website concerning such error. Because my computer is a new one (HP Pavilion), there shouldn’t be problem in hardware. Moreover, all other application programs work well.
I tried some tricks they introduced (most are arranging the registers), but in vain. Having communicated with the technical support in Taipei, they said cannot re-produce such issue.
There is no any clip corrupt. More frustrating is that I can burn the individual clips or several short chapters (made from the same clips), but I could not burn the “big” chapter (of all these 30 clips) with title, music and effect.
Can someone help? Thank you in advance.
Sincerely Yours,
Zaroy
