photoimpact 10 smartdownload trouble
pookie100
i am connected thru a lan dsl i canot get smartdownload to work says i have no internet connection but i do?? any help would be appreciated
sumner
I had the same problem...I read an earlier post that I had to disable all my firewalls in order to download, but that still didn't fix my problem...I went to yahoo search and searched photoimpact smart download, it took me to a trial download freebies that had all the "try them before you buy them" add ons the same as in the smart download and installed them all individually, it worked. Here is the site address...go to dowload components:
http://www.ulead.com/pi/esd.htm
Good Luck!
Good Luck!
greenboy
Could this be related to local firewall settings? I've tried a lot of different firewall software, and some of them can be rather opaque until you RTM ; }
Some port might be required which isn't currently open and the firewall needs to be set to allow it perhaps?
Heck, ever since cookies started being an issue, I've been turning THEM off except for certain sites, and sometimes something won't work and I realize I need cookies enabled just for that site/process.
Isn't the internet fun? ; }
greenboy
I was using Trend Micro and found it among the best. Too bad I'd have to uninstall what came with System Mechanic Pro (Kaspersky, which is also great) to reinstall my still current registered TM Security version and tell you what might be the cure. Maybe I'll have a reason to use Smart Download and will be able to tell you whether it's poking for some port that needs to be available...
maryna
PhotImpact 10 smartdownload problem
pookie100
to maryna
u have photoimpact closed when u try to install the components? try having it closed and then install the components did u get the downloads from the ulead page?
emailme pookie100@alltel.net
Aario
Thanks Sumner!!!!Sumner the all exalted wrote:I had the same problem...I read an earlier post that I had to disable all my firewalls in order to download, but that still didn't fix my problem...I went to yahoo search and searched photoimpact smart download, it took me to a trial download freebies that had all the "try them before you buy them" add ons the same as in the smart download and installed them all individually, it worked. Here is the site address...go to dowload components:
Good Luck!
