TRANSPARENCY HELP
NUTZ
TRANSPARENCY HELP
I HAVE A GREEN STAR WITH BLACK BACKGROUND WHICH I WOULD LIKE TO MAKE THE BACKGROUND TRANSPARENT. IM USING THE MAGIC WAND TO SELECT THE GREEN AREA BUT NOT QUITE SURE WHAT TO DO AFTER THAT ..PLEASE HELP
- VikingAnimations
- processor: AMD A4-6300 APU with Radeon HD Graphics 3-7 GHz
- ram: 4 GB
- Hard_Drive_Capacity: 1 TB
- Corel programs: Ulead GIF Animator 5.05, MotionStudio 3D
Two ways to do this:
1. Click the Selection Options button on the Attribute Toolbar. Select "Inverse" then click Selection Options again, select "Make Selection Area Transparent." One more time and then select "None."
2. After you select the green area, click "Copy" then "Paste." You will have a new Object in the Object Manager that is just the green star with a transparent background. Then hide or delete the original with the black background.
NUTZ
ok i find that when i save the animation as transparent if has a white edging that when i add this star image into another GIF with green background is very noticable...so i made the transparent background green and repeated the steps gettting rid off the white edging...any other way around this?...also it seems that the transparent process looses sharpness... the star is not as CRISP... is this normal?....i havent fineshed the work yet cuz i been to busy but here is the star before n after tyvm again.....i also posted another topic on moving objects
NUTZ
- VikingAnimations
- ram: 4 GB
