two movies and a data file
rdsatkaycee
Post by rdsatkaycee »
Is there any way to put two short movies and a data folder (contains documents and photos) on a dvd so that the movies play as well on a standalone as they do on a computer? I realize a computer will have to be used to access the data folder. TIA
maddrummer3301
Post by maddrummer3301 »
Read this thread:
After you create dvd folders on the harddisk you simply add them
in the burning stage to the Nero compilation.
Or, in MF4 there is an option to include a data folder for data files.
http://phpbb.ulead.com.tw/EN/viewtopic.php?t=10441
Hope this helps,
MD
rdsatkaycee
thanks Madrunner. I am anxious to try both of these. I do have the two short movies on the hard drive as video. Need a little help though when you say the nero compliation. This is a compliation from what? Which area of Nero do I use. I'm using Nero 6 and MF IV. Thanks again.
maddrummer3301
In MF4 when your ready to burn the dvd in the output creation module (last step).
Click on the down arrow on the right to display additional burning options.
You will see create dvd folder (a file and directory image on the harddisk same as on the dvd, except it's on the harddisk).
Uncheck "Burn the disk" and check "Create dvd folders" etc.
The option to add a folder is only when you burn the disk.
It's under the one of the bottom icons for burner options.
You could check all 3 burning selections I think, never tried it.
Or, after the VIDEO_TS folder is created on the harddisk open up Nero 6.
New -> select DVD -> Dvd-Video.
Then do as the other post says.
In the compilation screen of nero you can add folders next to the VIDEO_TS and AUDIO_TS folder (you don't need the audio_ts folder).
Hope this helps,
MD
rdsatkaycee
Madrunner........I'm a little closer I think.
So many bugs and not enough time to erridicate them all!
Had problems with Nero bugs, then finally was able to add the two videos and make working DVD but couldn't figure out how to add data files.then tried MV 4 and there was a bug importing one of the videos from hard drive, then tried it from dvd in the dvd drive and it worked,, then added the other video then the data files and am buring as I write this. I will let you know how this works.
rdsatkaycee
Never could get Nero to work because of bugs. Finally got MF4 to work, but had to backup one movie from original dvd rather than folder on hard driver. Can't figure that one out, but important thing is I've got it going. Thanks, Madrunner!
