HELL..... I hope someone can help me! there's a lot of unresolved forum items around this issue, concerning VS7 and 8. I've been searching here for 5 months to try and get the solution, so now I post.
Using Video Studio 8 (ALL 3 patches installed), on a PIII 800, 512Mb RAM, c:11Gb, NTFS free space & d:40Gb, NTFS free space with a 16Mb Voodoo Banshee (yep the banshee is still screaming along and the drivers are wonderful - so no problems there) under Win2k (every patch known to man is applied) with a Firewire to Dv-Avi on my JVC DV video camera.
DMA mode is enabled
Write cache for both HDD's is disabled
Recently formatted HDD and reinstalled everything from scratch and it's buzzing along with a nice clean registry, no more Microsoft updates left to install as they're ALL there now. Defragged to perfection after deleting the swap file and booting to Safe mode (yep I remembered to reinstate it 1024Mb to 1200Mb). This is one happy puppy with her system at full speed ahead and it is STILL quite fast....!
I've got everything set to PAL for Australia - here are the settings as per VS8 automatically detecting them after the first clip was captured:
Microsoft AVI files
24 Bits, 720 x 576, 4:3, 25 fps
Lower Field First
DV Video Encoder -- type 2
PCM, 48.000 kHz, 16 Bit, Stereo
Changing to DV Video Encoder -- type 1 makes it worse.
Changing to Frame based makes no difference.
Changing to MPEG works well, but darn it I hate the transcoding and it's a painful exercise in time consumption/wasting.
Changing to VS5 also works well, but I SHOULD be able to use exactly the same settings for VS8 and capture without so many problems!
Pinnacle Studio 9 trial captures like a dream (wish I'd bought that instead).
I've got dropped frames, jerky capture with stripes wherever motion appears on the video, choppy sound and a headache.
If you can resolve my issue, you can probably help everyone else with the same solution. I've got a nagging feeling there's a problem with VS7 & 8 because I haven't come across a single post where the user has claimed their problem is fixed, just work arounds ARRGGHHHH!
simply Deb
