Hi - First thanks to those contributing to this forum, particularly the regulars who answer queries. I read most posts just in case I come across the problem. I searched but can't find proper answer to this. I have created a mpeg using VS9 and Dolby and there is no audio. The file settings are:
PAL DVD
3,472,856 KB size
Video
MPEG 2 Video, Lower field first
24 bits, 720x576,4:3
25 Frames/sec
Variable bit rate(max 6500)
Audio
Dolby Digital Audio
48000Htz, 2/0(L/R)
192Kbps
Windows media player won't play it and just shuts down(I read it doesn't support Dolby anyway) but DVD Workshop will play it but no sound
When I created the same file with LPCM audio it works fine but I was hoping to use Dolby for size purposes. I tried creating the MPEG twice but no go.
The Project properties in VS are:
PAL (25 fps)
Microsoft AVI files
24 Bits, 720 x 576, 4:3, 25 fps
Lower Field First
DV Video Encoder -- type 1
PCM, 32.000 kHz, 16 Bit, Stereo
Would apprciate any help
Liam
Cannot get any audio when rendered with Dolby
BIGDAWG2005
Hi LiamoLiamo wrote:Thanks, thought I did but might not have. Will try it.
Ulead DVD WS 2.232
Ulead VideoStudio 8
Ulead PI XL SE
Ulead Cool 3D Producion Studio 1.01
Iomega Super DVD Writer
Can you confirm which version of VS you are using.
This post indicates VS 8 but in your first post you say 9???????
VS8 does not support Digital Dolby without purchasing the AC 3 plugin from ulead.
If you are indeed using VS 8 then an upgrade to VS 9 is advisable.
Using VS 9 will allow you to create video using DD.
My operating system is win 2k and only supports windows media player 9. I had to install a free AC 3 plugin allowing the player to use DD
http://ac3filter.sourceforge.net/
Hope this Helps
Trevor
Liamo
Liamo
Nope
Tried what BIGDAWG2005 said and updated with UVS9Full_Patch1_5in1. Still no sound from MPEG outside VS9. Noticed that the 'about' shows
Ulead Video Studio 9.00.0000
Ulead Dolby Digital Powerpack 1.0
Should it not be 9.01 or something if there is an update added
Can anyone help. Have to do an ordination ceremony and my soul is at stake here!
L
L
My system will not play Digital Dolby unless I install the free A/C3 plugin from sound forge.
Have you installed as my first reply.
TrevorMy operating system is win 2k and only supports windows media player 9. I had to install a free AC 3 plugin allowing the player to use DD
http://ac3filter.sourceforge.net/[quote/]
Liamo
