No props, no themes ??
RedBaron
Post by RedBaron »
Anyone knows the solution to this ?
I own version 3 and 4 of CD/DVD PictureShow and when I make a new installation of the software (either one) I am unable to see props or themes??
However, if you look in the folders, the UFO files are there...
I do clean installs. (this is a new PC)
note: it worked before on my old PC ???
any help would be appreciated, thanks.
Pierre
michaeltee
motherboard: HP 82F1
processor: Intel Core I5 7400 3 GHz
ram: 16 GB DC
Video Card: Intel HD Graphics 630
Hard_Drive_Capacity: 2TB Hybrid
Monitor/Display Make & Model: Samsung S24D300
Corel programs: Installed: PS Pro 2021, VS Ultimate 2020
Post by michaeltee »
Hi Pierre,
Re PS4, sometimes the installer does not generate a needed file called "index.smp" in the folders that contain your themes and props. Go to C > Program Files > Ulead Systems > Ulead CD & DVD PictureShow 4 > Content > Props and check all of the individual sub-folders (Baby, Sport, Nature, etc...) for the "index.smp" file. Each folder should contain one "index.smp" along with various .UFO graphic images (and possibly some other files). Also check the "Presentation Style" and "Menu Template" sub-folders for the same thing. If you find that these sub-folders DO contain .UFO files but NOT an "index.smp" file then the problem is your Props and Themes are installed but not recognized by PS4 due to the missing index files. Let me know if this is the case and I can probably help you solve the problem.
As for PS3, I can't help you as I have not used the program.
-Mike
RedBaron
no Index files
Post by RedBaron »
Hi Mike, thanks for the answer. I did a re-install of PS4 and sure enough all UFO files are in the appropriate folders but no index.smp in props or presentation styles.
Can you help?
Pierre
michaeltee
ram: 16 GB DC
Hey Pierre,
Send me an email or PM with your email address and I'll send you the index files and instructions.
-Mike
RedBaron
Post by RedBaron »
For record purposes, the index.smp files received correct the situation 100%.
Thanks to Mike again.
Pierre
michaeltee
ram: 16 GB DC
Glad to hear it worked for you Pierre! Happy to help :D
-Mike
Qutman
Post by Qutman »
michaeltee wrote:(...)
Re PS4, sometimes the installer does not generate a needed file called "index.smp" in the folders that contain your themes and props. (...)
-Mike
Hey Mike,
I'm new here, signed on because I got the exact same problem. Could you help me too please?
Please mail or PM the solution to me. Thanks man!
Qutman
Post by Qutman »
Got Mike's answer, thanks for helping!
diogenesx
Sme Issue
Post by diogenesx »
I'm having the same problems as well. Could you post or e-mail me the files? diogenesx@gmail.com.
On a side note, is there anyway to force the install to generate these files? I mean, why the heck does this happen?
Kyle
michaeltee
ram: 16 GB DC
Re: Sme Issue
diogenesx wrote:I'm having the same problems as well. Could you post or e-mail me the files? diogenesx@gmail.com.
No problem Kyle. I'll get in touch with you later this evening. As to "why", I wish I knew! The installer is supposed to generate these files but for unknown reasons it sometimes fails to do so. If there's a way to force it I'm not aware of it. The good news is, the procedure I mentioned seems to work for just about everyone.
-Mike
Phil L
Re: index.smp issue
Post by Phil L »
Hi Mike
Sorry to be a pain, but like other people here, I'm also missing the index.smp files (tried reinstalling a couple of times but Pictureshow 4 doesn't ant to create them), is there any chance you could send me the files to belfield349@hotmail.com.
Thanks for your help
Phil
ronaldoreyes
Post by ronaldoreyes »
Hi Mike apparently i am having the same problem too.. could you pass the instructions on how to make this work.. thanks.. also .. i tried installing the free download pack.. and that's the only thing that shows up on the menu theme...
michaeltee
ram: 16 GB DC
ronaldoreyes wrote:Hi Mike apparently i am having the same problem too.. could you pass the instructions on how to make this work.. thanks.. also .. i tried installing the free download pack.. and that's the only thing that shows up on the menu theme...
If you could PM me with your email address I'll try to help.
drmom11
Post by drmom11 »
It sounds like this could be related to the problem and solution posted at: http://phpbb.ulead.com.tw/EN/viewtopic.php?t=9972 titled CD DVD PictureShow4 Installation Problem.
ronaldoreyes
drom , i tried reading that topic and unfortunately no i does not help.. its weird coz before the installation works and after reformatting my pc i tired installing pictureshow4 again .. the props and themes wont load. but the free download pack that i installed loads.. i also tried copying the contents of the other folders like (sports,fantasyland , etc. etc..) into the free download folder and still it wont show up...
