I have a few old VHS kids movies that I want to move to the DVD player. I gess full DVD resolution is a no go.
I am sure you guys have gone through this before.
Thanks.
JCG
Please on what resolution to use to capture VHS footage.
maddrummer3301
Shouldn't be any problem with full resolution going by your machine specs.
NTSC Specs (USA)
FrameSize = 720x480
Aspect Ratio = 4:3
Fielding = Interlaced (top or bottom field first dependent on the capturing device).
Video_Bit_Rate = 4000kbs to 8000kbs (Variable or Constant) play with it.
Audio = Your flavor, they should all work if you have a good dvd player.
Going with mpeg or dolby(preferred Dolby) is better. Uses less disk space which allows more space for the video content.
So you can fit more content on a dvd using Dolby Audio because it's compressed.
Hope this helps,
MD
NTSC Specs (USA)
FrameSize = 720x480
Aspect Ratio = 4:3
Hope this helps,
MD
