Slide Show and transitions
gomactrading
Post by gomactrading »
I have a slide show of many images. Failed to set up the duration of display, the random transitions and their duration. Is there a way to change the display seconds, to force random transitions and change their duration after the project has beeen created?
Post by Trevor Andrew »
You do not say what version of VS you are using?
You can change the image duration by selecting adjacent images (Shift + Click)
Then Clip / Change image / colour duration.
You cannot batch change the transition duration, but you can set the default from File / Preferences /Edit tab.
Then General / tick Use default transition effect.
Now drag all images to a new library page, (creating a thumbnail copy) delete the images from the timeline, now drag back the images from the library.
Hope this helps
Trevor
