ok - I give up. I am trying to burn a mpeg file created from Canopus EDIUS. Never ran into this problem before. Can someone tell me what this error code is, ir is there a magic decoder ring somewhere on the web I can look this up?
Man, I hate cryptic error codes.
Unspecified error 800413a4
bseidner
rad
mr_fatron
rad
i have 3 non-motion menus only a 50 min dvd. Now the original file I had created using ws2 but now have upgraded. Should I delete that and try again in the new version...well I guess Im gona have to!mr_fatron wrote:I started getting this error the other day. I had 3 motion menus back to back, and dvd workshop didn't seem to like it. I deleted one of the menus and it started working okay.
mr_fatron
In my 2 weeks of working with DVD worshop, it's been my experience that if your project gets messed up in version 2, then you do the upgrade to 2.253, your project stays messed up. I just got to experience the joy of starting a 100+ menu interactive DVD over because of similar problems. On the bright side, I know how to use the software now, so version 2 of the DVD is much nicer than version 1.
rad
ooo sounds painfull! LOL We thanks for the input. I will trash it and start fresh.mr_fatron wrote:In my 2 weeks of working with DVD worshop, it's been my experience that if your project gets messed up in version 2, then you do the upgrade to 2.253, your project stays messed up. I just got to experience the joy of starting a 100+ menu interactive DVD over because of similar problems. On the bright side, I know how to use the software now, so version 2 of the DVD is much nicer than version 1.
rad
well I did everything from scratch. Everything went fine. When I review it in the FINISH window all is fine. Disc buring went fine. The final dvd???? 2 of the 3 menu links do not work!!!!!!!!!!!!!!!!!!!!!!!!!!
I can't figure it out!!!!!!!!
by chance could it be the media???
Im at my witts end here!!!
jjdon1
800413a4
I've been using DVD workshop on a friends machine - just a one-off of vacation photos for me. We kept getting this error message: error 800413a4. The last time I happened to be sitting at the computer when it happened. At the very instant that the error message popped up, a windows (XP) message popped up, "You are running very low on disk space on drive C:, etc.". Even though the disk writer said that there was enough space on the drive (not a lot more- .2 gig), it was not enough. I'm still writing the disk again, after some disk housekeeping, but it's pretty clearwhat happened. I'll post this on the other two threads with this error as a keyword, too.
