I have two projects. One is 1:20 long, the other is only 0:32 long.
The longer project runs playback very smoothly, while the shorter project runs playback very jerky. There appears to be a lot of disk thrashing during the jerky playback of the shorter project, while disk operation is much smoother during the playback of the longer project. Also, the shorter project with the jerky playback takes a while to respond to the STOP button, or any other button for that matter, while the longer project responds virtually instantly to any and all buttons.
My system is a built around an ASUS A7N8X Deluxe V2.0 with AMD 3200+, 1 GB PC 3200 SDRAM @ 400 MHz, and a 60 GB 7200 RPM Ultra ATA Maxtor disk with 30 GB free. DMA is enabled for all drives. I also have a 200 GB external USB 2.0 Seagate with 160 GB free.
That should be plenty of resource for what I'm doing, and as corroboration of that, one project runs playback smoothly, while the other one is jerky.
Here are the properties of the project that runs a jerky playback.
- NTSC drop frame (29.97 fps)
MPEG files
24 Bits, 720 x 480, 29.97 fps
Field Order B
(MPEG-2)
Video data rate: Variable (Max. 6000 kbps)
Audio data rate: 192 kbps
MPEG files
Field Order B
(DVD-NTSC), 4:3
Audio data rate: 160 kbps
