The HC1 captures high definition (HD) video on the same standard mini-DV tape cassette that most DV camcorders use. Instead of recording in DV format, which is only slightly compressed, the HC1 records to tape in more compressed Mpeg2 HDV. The net result is that the HC1 can store 60 minutes of HD video on the same cassette that currently records 60 minutes of standard definition (SD) video in a DV camcorder.
Computer Configuration: VS9 performance, when editing HDV is “acceptable” on my computer, which is a 2-year old Dell 8300 with 3.0 GHz. P4 HT CPU, 1GB memory, 76GB Western Digital Raptor (SATA, 10,000 RPM) and 130 GB WD (7200 RPM).
CAPTURING HDV
(1) The first step is to download and install the HDV plugin for VS9. Note that the Mpeg4 plugin interferes with the HDV plugin if it is installed later, so be sure to install it before you install the HDV plugin.
(2) Start VS9, select menu File/New Project, select menu File/Preferences/Capture tab: check “Stop Tape When Capture Stops” and “Show Drop Frame Information”
(3) Connect the HC1 to your PC using the firewire cable, select the CAPTURE tab and click “Capture Video” on the leftmost panel. Set the HC1 to Play/Edit mode.
(4) The Capture panel slides out and the Source control should display “Sony-HDV” (if not, see (1) above), the Format control should display “Mpeg”. Leave the Duration control set at “00:00:00.” Note that Mpeg is the native format on the tape and so I recommend capturing in this format to place the least computing load on the computer.
(5) The capture properties can’t be changed in the capture module and are locked to the following values, in NTSC land:
NTSC drop frame (29.97 fps)
MPEG files
24 Bits, 1440 x 1080, 29.97 fps
Upper Field First (just the opposite of DV capture)
(MPEG-2), 16:9
Video data rate: 25000 kbps
Audio data rate: 384 kbps
(6) Use the tape controls on the Capture screen to position the video tape and click “Capture Video” button to begin capture. My CPU loafed along at 20% – 30% busy during capture. Hit “Stop Capture” to end the capture process. Ignore the stalling that is evident in the playback window during capture. The capture file will be perfect. Use the HC1's LCD screen to monitor capture progress. Ulead should fix its capture display because there is ample CPU power available to provide a smooth video in 16x9 aspect ratio.
(7) Select the EDIT tab in VS9. Click “Yes” to the message “Do you want to set Project Settings to Match Video Properties…”
EDITING HDV
The usual editing controls work well when editing HDV. You can do “virtual” cuts with the “Multi-Trim” control, and real cuts (making a video file) with the “Save Trimmed Video” control. Transitions (I tried “Cross Fade” and “Flying Flip” worked well, although VS9 had trouble playing back the project around transition points, it did not crash. (Speculation: AFAIK, the transitions are the original standard definition ones and thus may be forcing VS9 to convert properties on the fly, during playback.). Audio clips work as they should with no problems. Everything that I tried worked quite well.
CREATING PROJECT VIDEO FILES
There are some additional considerations with high definition because Mpeg2 HDV files are HUGE and conventional DVD disk formats are not compatible with high definition bitrates or frame sizes. High definition DVD players and media (e.g., the long awaited Blu-Ray) don’t seem to be a viable option because they are barely existent, priced out of sight, and/or mired in squabbling about standards.
However, a clear alternative is to store highly compressed high definition video files on conventional DVD media. Mpeg4, H.264, and Divx are far more efficient video compressors than Mpeg2 and can fit a full-length movie, as a file, on an ordinary (non-HD) DVD disk. The downside is that playback requires a new DVD player with a more powerful processor. The good news is that these products are available now and reasonably priced.*
Another playback method is from miniDV tape to HDTV through the HDR-HC1 component video cable. However, Ulead’s HDV plugin does not (yet) support the Export of a high definition project back to an HDR-HC1 tape. IMO, this is a mixed blessing because the HC1 is too expensive to wear out the tape heads using it as a playback device.
CREATING DIVX HIGH DEFINITION VIDEO FILES (my preferred workflow)
(1) Download and install the Divx codec from www.divx.com. Version 6.1 is the latest as of this writing.
(2) Start Video Studio 9, open your project, select SHARE tab and click on Create Video File/Custom,
(3) In the “Save As Type” control, select “Microsoft AVI Files”. Click the Options button to open the “Video Save Options” window. Select the “AVI” tab.
(4) The “Compression” dropdown control should present a list of video codecs. Select the Divx codec,
(5) Click the “Configure” button, which should now be enabled,
(6) The Divx Configuration window opens. In the Main tab, if you want best resolution (1080 lines), select Certification Profile = “Unconstrained”, select Encode Mode “Bitrate Based” and enter the number “5000” kbps, which seems to have very few compression artifacts. [If you want to produce 720 line video, Select “High Definition” profile and 3000 kbps.]
(7) On the “Codec” tab, set Encoding Mode = “Insane Quality”
(8. On the “Video” tab, select “Custom Resize” and enter the frame dimensions: width = “1920” and height = “1080”. Note: if you enter the HC1’s true horizontal frame size (1440), the AVLP2 displays incorrect aspect ratio. [For 720p quality, enter 1280x720 frame size.]
(9) On the bottom left, there is an Interlace control where you can select “Preserve Interlace”, “Deinterlace,” or “Progressive Source”. The HDR-HC1 has a native Field Order = Upper Field First. I have noticed a “comb-like” effect on vertical edges during horizontal panning with interlaced video, which disappears if I select “Deinterlace.” However, not all players can handle 1080p playback…
(10) Close the Divx Configuration window. Set Audio properties as desired.
(11) Select Video tab, set Field Order to match what you selected in (9) above: “Frame Based” if you selected Deinterlace, “Upper Field First” if you selected “Preserve Interlace”. Frame Rate = 29.97. Frame: select “User Defined” and enter 1929x1080 for the dimensions. [For 720p, enter 1280x720.] Close the window.
(12) Enter a File Name, select SAVE and go to bed because transcoding Mpeg2 HDV to Divx HD will take a long time. However, the resulting video file size will be 10% - 20% of the size of an equivalent Mpeg2 HDV file.
(13) Preview the playback using, for example, VLC Media player (http://www.videolan.org/) on the PC
(14) Use something like Roxio’s Easy DVD Creator to write the Divx video file on a Data-DVD. Playback using, for example, AVLP2 player on your HDTV set.
CREATING MPEG2 HDV VIDEO FILES Note: You don't have to make an Mpeg2 file if you have made a Divx video file.
(1) With the project file open in Video Studio 9, select SHARE tab and click on Create Video File
(3) In the “Save As Type” control, select “Mpeg Files”. Click the “Options” button to open the “Video Save Options” window. Select the “Compression” tab. This should default to Mpeg2 and CBR = 25000kbps.
(4) Select the General tab. Select the 1440x1080 frame size if you want the fastest render time for the HDR-HC1. 1280x720 and 1920x1080 are also selectable but will increase render time. Set Field Order to Upper Field First for fastest render. You can also select Frame Based for progressive playback.
(5) Name the file and hit the SAVE button. If you preserved the original capture video properties, rendering will not take long. However, the video file will be huge.
*Divx HD certified DVD and hard disk playback devices are already on the market and I expect so see Mpeg4 players soon. Here are links to several of them.
I-O Data Avel Link Player http://www.iodata.com/usa/products/prod ... P2%2FDVDLA
Buffalo Link Theater http://www.buffalotech.com/products/pro ... egoryid=18
Tivx M-3000, M-5000 www.tvixusa.com/
