Flipping clips on Va and Vb
vroman
Post by vroman »
I have place a series of clips on the timeline in both Va and Vb. I need to swap them because I need to place a clip in the middle and in order for the transitions to be smooth they need to be swapped. Is there a way to grab a series of clips and tell the program to leave them in the same place but put those in Va to Vb and vice versa? Thank you
Helge
Post by Helge »
This is one of the greatest advantages of the new eding method of MSP8, that this problem no longer exists. You do all the eding on just one track and so you can easily insert or remove some movies.
One way to so solve that problem with MSP7 is to cut one movie (before or after the position where you want to insert the new movie) anywhere between two transitions and move the second half to the other track, so that the to halfs align without gap and without overlap (no transition). Or instead cut the inserted movie.
