Windows XP 64 bit edition
Strtline
Post by Strtline »
Hello:
Does anyone know if Ulead has plans to support the Windows XP 64 bit edition. I have Videostudion installed on a 64 bit dual core system and it works but a) does not take advantage of the 64 bit dual core processor and b) updates wo't install
2Dogs
Post by 2Dogs »
Hi Strtline,
VS certainly will run quicker on a dual core system - both AMD and Intel dual core cpu's will render video files noticeably faster than a similarly clocked single core cpu.
I'm not sure if you're saying that you are running a 64 bit operating system with your 64 bit dual core cpu - perhaps you might fill in the "system" info in your profile. It would be good to get more results from someone with a fast dual core setup. Certainly if you have an AMD 64, you won't find many applications that can take advantage of the 64 bit architecture - and I believe Linux is the only OS out there right now with a 64 bit version. The improvements in the AMD 64 made it about 25% faster for a given clock speed than the previous 32 bit Athlon, even running plain 32 bit Windows, but its 64 bit capability came years in advance of a 64 bit operating system.
It's anyone's guess what will happen in the future - 3 months is a long time in pc development - and on Wall St, they think it's long term planning when someone asks, "what's for lunch?"
Strtline
Windows XP Pro 64 bit edition
Post by Strtline »
Hello 2Dogs:
Thanks for the replay. Did as you suggested and updated my profile. Updated my system from Athlon 3800+ to 64 bit dual core version of same processor. Also added some SATA 300 drives. Everything else remained the same. AVI to MPeg conversion of 2+ hour source file used to take 11 hours (2 pass - variable bit rate - 6000). With dual core 64 bit takes 4+ hours. Running Windows XP 64 bit version but VS9 still only 32 bit not really taking advantage of processor. Just wonder what would happen if there was a 64 bit version of VS9!!
Strtline
