HOW THE HECK DO YOU EDIT TEXT???
daverave
Post by daverave »
This is really annoying and the manual is worthless!\\
sorry to rant BUT...
There are bunches of text in the library - UPI this UPi that
how the heck do you put your own type in them? thanks
kamiller42
Post by kamiller42 »
Assuming you know how to add the Text object to the image, have you tried right clicking the object? The first option is "Edit Text". You can also double click the object while it's selected. The editor goes into text edit mode.
daverave
Post by daverave »
thanks but,
are'nt you talking about the ordinary text? that's easy.
I'm talking about the easy palette UPI text. My right click has no
such option for these. double clicking seems to have no effect
either.
kamiller42
daverave wrote: I'm talking about the easy palette UPI text. My right click has no
either.
I was talking about the easy palette. However, this option will only appear if the text effect is a single layer object, like S01. For an effect made with multiple layers, like S03, make sure the Layer Manager is visible with Layer tab selected, add text effect object to image by double clicking, right click, select Ungroup, select each layer and edit the text, and regroup objects.
Take note of the "T" icon on the right hand side of the layer which denotes a text object you can edit.
daverave
Post by daverave »
ok, thanks a lot. I got some of it to work anyhow. Just need to
fiddle with more.
is there a part of the manual that covers this? independant tutorial?
thanks
