Hi.
Have I got the whole thing wrong, or do every time you change your video file length, before previewing it, you have to go through the whole process of creating the file (which can take several minutes)?
heebiejeebieclub.
Previewing Video
You apparently have your playback preference set to High Quality. Changing that to Instant will change the preview to, um, instant.
Jeff
Dentler's Dog Training, LLC
heebiejeebieclub
This is just from memory because I am at work, but I believe it is under File>Preferences, then either the first or second tab you'll find your playback preference - either Instant or High Quality. I'm sure someone else will clarify.
Jeff
Yes -- its under the first General Tab of File > Preferences, about two thirds of the way down: "Playback Method".
And don't play around with the quality slider too much -- especially not down to zero!!! Either leave it at its default of 70 or 80%, or try it higher. But going lower is asking for poor quality and probably also problems...
