MSPro8 Smart Compositor Designer released...
Terry Stetler
Post by Terry Stetler »
http://www.ulead.com/msp/free.htm
The MediaStudio Pro 8 Smart Compositor is an all new tool that lets you quickly create professional-quality opening sequences or segues with pre-made masks, frames and moving paths. Even if MediaStudio Pro is not your primary NLE, Smart Compositor can come to the rescue. Compose your sequence, then simple render it out as avi or whatever format you need, and export to your main NLE.
MSPro8's Smart Compositor comes with 22 ready-to-use theme templates already installed.
The Smart Compositor Designer plug-in makes creating new templates easy. Create your own sequence components such as masks and frames, then combine them as a composited sequence on the Video Editor timeline. Or use existing templates as a base for further modification. Output templates directly from the Video Editor. Template generation is automatic and includes an optional installer to mount the new template in the Smart Compositor library.
The Smart Compositor Designer is available at no cost to all users of MediaStudio Pro 8. Available in English, the Smart Compositor Designer is compatible with all MediaStudio Pro 8 language versions.
Features
*Seamless integration with the MediaStudio Pro 8 Video Editor
*Output as template file sets or wrapped with an installer to mount new templates in the Smart Compositor library
*Choose any frame for the template reference thumbnail
*Choose the Smart Compositor Library into which new templates install
Terry Stetler
Dave DeLancey
Post by Dave DeLancey »
Terry - this plugin completely crashed msp8 for me - had to completely reinstall - tried to add/remove the smart composter from control panel and said it couldn't find it - pretty crappy - Win2K all updates
krwzmann
Post by krwzmann »
Yes it's finally here! Ah man sorry to hear that it crashed your system Dave. I've got a couple of projects for clients on my system right now so now i'm hesitant to install this plug-in. :o I'm on Win XP SP2.
tyamada
Post by tyamada »
Others are having problems after installing Smart Compositor Designer.
See posts: http://phpbb.ulead.com.tw/EN/viewtopic.php?t=10079
krwzmann
ah crud
Post by krwzmann »
I gave it a shot on my older system (the one without any projects) and after install and restart...it crashed my system as well. A small window pops up titled u32Cfg witha big red x and says ULead.dat .
Cruddy but at least it wasent on my main system with my projects. Thanks for the heads up guys. Man o man though. Need a fix!
krwzmann
Post by krwzmann »
Dave DeLancey wrote:Terry - this plugin completely crashed msp8 for me - had to completely reinstall - tried to add/remove the smart composter from control panel and said it couldn't find it - pretty crappy - Win2K all updates
I had the same problem too when trying to remove just the plug in. Can't find it. Doh!
krwzmann
Post by krwzmann »
I'll try a Windows System Restore to a few days ago. It's the first time trying system restore so let's see if it can work miracles!
HankM
Post by HankM »
just installed smart composer designer. Restarted computer. went to start MSP8
all I get is a small box : u32cfg ulead.dat with a red X button and ok botton. I click ok, and nothing happens.
I finally had to uninstall and reinstall MNP8
Hank
richardnau
Post by richardnau »
Same thing for me (Win XP Home SP2). Should have checked here before installing.
There is at least one report on the MUG-SW forum of the same problem.
Has anybody had success with installation of Smart Compositor Designer (since it was released... I'm sure it will have worked for the beta testers and presume that something has gone awry in the final packaging for general release...)?
I have reported the problem to the Ulead tech support team but I guess it will be a few days before I hear from them!
Video editing PC:
C2D E6600 CPU on Asus motherboard
2GB dual channel DDR2 RAM
7600GT PCIe video card
320GB RAID 1 SATA system drive
400GB RAID 1 SATA documents drive
400GB video drive
Samsung and Pioneer DVD burners
Vista Home Premium 32 bit
tyamada
Post by tyamada »
To uninstall Smart Composer run the installation again, you will be asked if you want to remove program or not.
Rick O
Post by Rick O »
I got the designer installed and I can open it but nothing seems to work the way the very very short instructions say . I am havingt the same problem with the compositor. I creat a new theme and then can't view it or if I insert it in the timeline the program locks up. Hope a fix is on the way.
I've downloaded it and it installed OK.
I am using the ESD Download version of MSP8 that requires serial number entry not the internet activation version.
The new function is then located from the toolbar at the top of the screen
Project, Design Tool.
It requires that there be at least one video and one audio track for it to function.
Regards
Steve J
Rick O
Post by Rick O »
thanks for the reply.
Maybe that is why the designer isn't working. How do you get a video and audio track in there?
Just drag them to the timeline.
Haven't played with it yet but the impression I got was you create whatever you want on the timline in the usual way with overlays, filters, multi tracks etc, then run this designer to convert it into a Smart Composition.
It gives two options
1. Save as an exe file
2. Save to a folder
You give it a name and a category type which can be one of the existing categories or create your own.
richardnau
tyamada wrote:To uninstall Smart Composer run the installation again, you will be asked if you want to remove program or not.
Ummm...
So that 'appeared' to work, but result on attempting to run MSP8 is unchanged: the little dialog box with 'ulead'dat' in it and nothing else.
So now I have:
* no working MSP8
* no hotfix installed
* no Smart Compositor Designer.
Will keep an eye on the board and wait for a reply from Ulead.
To be honest, I'm expecting that lowest common denominator of solutions: reinstall.
Richard.
Video editing PC:
400GB video drive
