applying a texture to a cone
zaphodikus
motherboard: ROG-X570-F-Asus
processor: AMD 3950 - 16 core
ram: 64Gb
Video Card: AMD RX 6700
Hard_Drive_Capacity: M2 1TB
Monitor/Display Make & Model: 4K BenQ
Corel programs: VS 2023 Ultimate, Painter 2020
Post by zaphodikus »
creating a texture to wrap a lathe object and then get it to align - using cylinder mode. My object is conical, slightly, it's a bell, and it's dastardly hard to get the texture to wrap the shape, I'm missing something.
Where do you start with doing this, adjusting the texture offset and scaling just gets weird results, because the texture starts to repeat. What does the texture origin X+/X- and Y+- and Z +- apply really do?
Vicky V
motherboard: unknown
processor: Intel
Video Card: Intel
sound_card: Intel
Hard_Drive_Capacity: 237B
Monitor/Display Make & Model: Curved24"Samsung
Corel programs: VS ULT 2022
Re: applying a texture to a cone
Post by Vicky V »
Are you creating a texture with two faces as in back and front or a single face?
If is a single face you have to repeat its pattern whatever that is for your texture over the whole length of you image texture. Keep on increasing the length of the image till its fully wrapped by your 3D lathe object.
I used a back and front face in the same texture image for this sample, it was kind of tricky to make it fit, but got it perfectly fine by adjusting the length of the image texture instead of messing with the X/Y axis on properties...
Check this out... https://youtu.be/cYdCiA4y3To
