Scrubber shows green/pink bars
zaphodikus
motherboard: ROG-X570-F-Asus
processor: AMD 3950 - 16 core
ram: 64Gb
Video Card: RTC 6700
Hard_Drive_Capacity: M2 1TB
Monitor/Display Make & Model: 4K BenQ
Corel programs: VS 2021 Ultimate, Painter 2020
Post by zaphodikus »
I recently upgraded from an old nvidia to an AMD graphics card and got me a 4K display. 2 things. I'm using VS 2021 still
1. the thumbnails are a bit tiny on a 4K, is this me being stupid? Can we get bigger thumbnails in the clips window?
2. the scrubber is not usable, it keeps letting me scrub timeline, but when I release the scrubber I get pink and green bars. Like attached.
RobertOZ
motherboard: Asus Prime B550M-A WI-FI AM4 mATX
processor: AMD Ryzen 5 3600 3 6 GHz
Video Card: Asus Geforce GTX 1650 GDDR6 Driver 516 94
Hard_Drive_Capacity: 7 TB
Monitor/Display Make & Model: Philips 32" IPS LED, Samsung 28" 3840x2160 UHD 4K
Corel programs: VS2018, VS2021 & VS2022, MS 3D, MCC XL
Re: Scrubber shows green/pink bars
Post by RobertOZ »
To fix the resolution issue,
Go to Settings/System - Change the "Scale and Layout" to 150%
Next, right click on the VS2021 desktop icon and select Properties
Select - Compatibility
Change High DPI settings
Tick box - Program DPI
High DPI scaling override
Tick box -Override high DPI Scaling Behavior
From drop down box, select System(Enhanced)
click Apply/OK
I am sure that are some posts about the timeline issue, but have been unable to locate them
operating_system: Windows 11
processor: AMD Ryzen 9 5900X
ram: 32 GB DDR4
Video Card: AMD RX 6600 XT
Corel programs: VS 2021; PSP 2022; MS3D; ASP 3; DRAW2021
Post by Ken Berry »
I had the green/pink problem some months ago. Corel took over my computer for around 4 days on and off. In the end, the thing that resolved the problem, for me at least, was to play around with the Hardware Acceleration options. Try disabling Hardware Decoder first. That solved it for me, but if not, try the others. But to repeat, it was only one of them which caused the problem for me.
See https://forum.corel.com/viewtopic.php?p=392191#p392191
zaphodikus
ram: 64Gb
Sweet.
Putting the app into high DPI mode using the start menu shortcut "compatibility mode" settings RobertOZ gave us made the app look better.
Going in VS2021 and Settings/Preferences/Performance , and disabling GPU acceleration sorted out the green bars.
(Toolbar Icons still look a bit blurry, going to hack around more to fix that, but this is useable for now.)
Phew for a moment I thought my hardware upgrade was going to low me down. Thanks all.
Umm is 2022 4K compatible? worth upgrading if so.
ram: 32 GB DDR4
Post by Ken Berry »
FWIW I have had to apply the high DPI Settings. But it's easy and quick enough to do that I don't think about it and just do it.
